Armbian Task Management¶
Overview¶
TLDR; Keep task discussions in the forum. GitHub Issues are just for task metadata.
Tasks associated with code will have an issue created in GitHub, but all dialog regarding tasks will reside on the forum in a topic containing the github Issue ID of the task.
What is a task?¶
A task is something actionable that results in some sort of tangible output. ex: code, documentation, QA findings.
Example sources of tasks include: feature requests, bugs, QA, general following of development roadmap.
Not all support issues are tasks, but a support issue can generate a task.
Task Creation Procedure¶
- Create issue in Armbian GitHub Repo under appropriate milestone
- Copy the numeric ID of issue created
- Create new topic under the Tasks subforum on the Armbian Forums
- Use the the naming convention of
[ISSUE_ID] - Issue Name-
- Copy the URL of task subforum topic just created
Create comment on GitHub Issue with the following Content:
Text Only 1 2 3
Please keep all discussion for this issue on the forum topic available below: [URL](URL)-
Lock comments on GitHub Issue
Task tracking with GitHub Issues¶
GitHub Issues provide an easy method to track and filter tasks by using tags and milestones. Issues also make it easy to easily associate commits and merge requests with a task. Effectively we just use GitHub issues for the metadata for reporting.
Labels¶
Use labels identify the purpose of a task.
bugis used to tag tasks that address Armbian-level bugsnot-our-bugis used to identify tasks that are bugs in upstream code. They are not Armbian bugs, but may impact Armbian.enhancementis used to identify tasks that are new features for Armbian.
Milestones¶
Use milestones to divide tasks into claimed and unclaimed work.
claimed tasksmilestone contains tasks which have been assigned.unclaimed tasksmilestone contains tasks that need an owner.
Forum Tasks¶
Converting a topic to a task¶
Sometimes support discussions can become tasks. A forum admin can assist in moving the topic to Tasks forum group. A cooresponding issue will need to be created.
Future Process Improvements¶
Enhancements desired for this process (This should be a task!)
Issue Hook¶
Ideally we can have a forum topic created upon issue creation. This will save some time.
