Build options¶
These parameters are meant to be applied to the ./compile.sh
command. They are all optional. They can also be added to your build configuration file to save time. Default values are marked bold if applicable.
Main options¶
- BUILD_ONLY (comma-separated list): defines what artifacts should be built. Default value is empty string - will build all artifacts. Changing this option can be useful to build partial artifacts only. - u-boot: build U-Boot - kernel: build Kernel - armbian-config: build Armbian config - armbian-zsh: build Armbian zsh - plymouth-theme-armbian: build Armbian Plymouth theme - armbian-firmware: build Armbian firmware - armbian-bsp: build Armbian board support package - chroot: build additional packages - bootstrap: build bootstrap package - default: build full OS image for flashing
- KERNEL_CONFIGURE ( string or boolean ):
- prebuilt: Use precompiled packages (only for maintained hardware)
- yes: Automatically call kernel’s
make menuconfig
(add or remove modules or features) - no: Use provided kernel configuration provided by Armbian - leave empty to display selection dialog each time - CLEAN_LEVEL (comma-separated list): defines what should be cleaned. Default value is
"make,debs"
- clean sources and remove all packages. Changing this option can be useful when rebuilding images or building more than one image - make-atf = make clean for ATF, if it is built. - make-uboot = make clean for uboot, if it is built. - make-kernel = make clean for kernel, if it is built. very slow.
important: “make” by itself has disabled, since Armbian knows how to handle Make timestamping now.
- debs, alldebs = delete all packages in “./output/debs” - images = delete “./output/images” - cache = delete “./output/cache” - sources: deletecache/sources
(all downloaded sources) - oldcache = remove old cached rootfs except for the newest 8 files - extras: delete additional packages for current release inoutput/debs/extra
- REPOSITORY_INSTALL (comma-separated list): list of core packages which will be installed from repository
- Available options:
u-boot
,kernel
,bsp
,armbian-bsp-cli
,armbian-bsp-desktop
,armbian-desktop
,armbian-config
,armbian-firmware
- Set to “” to use packages one from local output or build if not available - KERNEL_KEEP_CONFIG ( yes | no ): - yes: use kernel config file from previous compilation for the same branch, device family and version - no: use default or user-provided config file
- BUILD_MINIMAL ( yes | no ):
- yes: build bare CLI image suitable for application deployment. This option is not compatible with
BUILD_DESKTOP="yes"
andBUILD_EXTERNAL="yes"
- no: default CLI package selection - BUILD_DESKTOP ( yes | no ): - yes: build image with minimal desktop environment - no: build image with console interface only
- EXTERNAL ( yes | no ): - yes: compile and install extra applications and firmware
- BSPFREEZE ( yes | no ): - yes: freeze (from update) armbian packages when building images (U-Boot, kernel, DTB)
- INSTALL_HEADERS ( no | yes ): - yes: install kernel headers
- EXTERNAL_NEW ( no | prebuilt | compile ): - prebuilt: install extra applications from repository - compile: compile extra applications in chroot
- CREATE_PATCHES ( yes | no ) Warning: This option is deprecated and may be removed in future releases - use the new
kernel-patch
/uboot-patch
/atf-patch
CLI commands instead. - yes: prompt right before the compilation starts to make changes to the source code for both U-Boot and kernel. From these changes patch files will be created and placed inoutput
directory. If you want these patches included in a normal run (without CREATE_PATCHES to say) these files need to be copied to the appropriate directories. Also see user provided patches. - BUILD_ALL ( yes | no | demo ): cycle through all available board and kernel configurations and make images for all combinations
- CARD_DEVICE ( /dev/sdX ): set to the device of your SD card. The image will be burned and verified using Etcher for CLI.
- EXT=rkdevflash to flash Rockchip images to eMMC either during image build or separately with flash CLI command (only works bare Linux, not Docker)
- CRYPTROOT_ENABLE ( yes | no ): enable LUKS encrypted rootfs
CRYPTROOT_PASSPHRASE="MYSECRECTPASS"
mandatory -CRYPTROOT_SSH_UNLOCK=yes
Default:yes
-CRYPTROOT_SSH_UNLOCK_PORT=2222
Default:2022
-CRYPTROOT_PARAMETERS="custom cryptsetup options"
Default:--pbkdf pbkdf2
(May not contain=
; separate with spaces) - Note: This function might not work well with all distributions. Debian Buster and Stretch were tested. For building under Docker you have to use privileged mode which can be enable inuserpatches/config-docker
. - Warning: This feature was added as community contribution and mostly functional. Under some circumstances though the prompt will not be shown. Therefore it should be considered experimental. Check here and here - Hint: If you want to do the encryption part from scratch check out this forum post.
Hidden options to minimize user input for build automation¶
- BOARD (
string
): set name of board manually to skip dialog prompt - BRANCH (
legacy
|current
|edge
): set kernel and U-Boot branch manually to skip dialog prompt; some options may not be available for all devices - RELEASE (
bullseye
|bookworm
|jammy
): set OS release manually to skip dialog prompt; use this option withKERNEL_ONLY=yes
to create board support package - ARMBIAN_CACHE_ROOTFS_PATH (
string
): bind mount cache/rootfs to defined folder - ARMBIAN_CACHE_TOOLCHAIN_PATH (
string
): bind mount cache/toolchain path to defined folder
Hidden options for advanced users (default values are marked bold)¶
- EXPERT ( yes | no ): Show development features and boards regardless of its status in interactive mode
- USERPATCHES_PATH ( userpatches/ ): set alternate path for location of
userpatches
folder - USE_CCACHE ( yes | no ): use a C compiler cache to speed up the build process
- PRIVATE_CCACHE ( yes | no ) use
$DEST/ccache
as ccache home directory - SKIP_EXTERNAL_TOOLCHAINS ( yes | no ) don’t download and use Linaro toolchains, by default placed in cache/toolchain (and configurable with ARMBIAN_CACHE_TOOLCHAIN_PATH)
- PROGRESS_DISPLAY ( none | plain | dialog ): way to display output of verbose processes - compilation, packaging, debootstrap
- PROGRESS_LOG_TO_FILE ( yes | no ): duplicate output, affected by previous option, to log files
output/debug/*.log
- NO_APT_CACHER ( yes | no ): disable usage of APT cache. Default
yes
in containers, but can be overridden - DISABLE_IPV6 ( true | false ): The distant future, the year Two-Thousand. Set false to allow Aria2c to use a modern ip protocol.
- NO_HOST_RELEASE_CHECK ( yes | no ): overrides the check for a supported host system
- USE_MAINLINE_GOOGLE_MIRROR ( yes | no ): use
googlesource.com
mirror for downloading mainline kernel sources, may be faster thangit.kernel.org
depending on your location - USE_GITHUB_UBOOT_MIRROR ( yes | no ): use unofficial Github mirror for downloading mainline U-Boot sources, may be faster than
git.denx.de
depending on your location - SYNC_CLOCK ( yes | no ): sync system clock on builder before start image creation process
- OFFLINE_WORK ( yes | no ): skip downloading and updating sources as well as time and host check. Set to “yes” and you can collect packages without accessing the internet
- FORCE_USE_RAMDISK ( yes | no ): overrides autodetect for using tmpfs in new debootstrap and image creation process
- FIXED_IMAGE_SIZE (
integer
): create image file of this size (in megabytes) instead of minimal - BOOTSIZE (
integer
96 ): set size (in megabytes) for separate /boot filesystem. Used if ROOTFS_TYPE set to non-ext4 - COMPRESS_OUTPUTIMAGE (comma-separated list): create compressed archive with image file and GPG signature for redistribution
- sha: generate SHA256 hash for image
- gpg: sign image using gpg
- 7z: compress image, hash and signature to 7z archive
- gz: compress image only using gz format
- xz: compress image only using xz format
- yes: compatibility shorcut for
sha,gpg,7z
- IMAGE_XZ_COMPRESSION_RATIO ( 1 - 9 ) Images compression levels when using xz compressor. Beware of memory consumption when going higher
- SEVENZIP ( yes | no ): create .7z archive with extreme compression ratio instead of .zip
- BUILD_KSRC ( yes | no ): create kernel source packages while building…
- INSTALL_KSRC ( yes | no ): … and pre-install these kernel sources on the image
- ROOTFS_TYPE ( ext4 | f2fs | btrfs | nilfs2 | xfs | nfs ): create image with different root filesystems instead of default
ext4
. Requires settingFIXED_IMAGE_SIZE
to something smaller than the size of your SD card forF2FS
- BTRFS_COMPRESSION ( lzo | none | zlib | zstd ): when choosing
ROOTFS_TYPE=btrfs
selectbtrfs
filesystem compression method and compression level. By default the compression iszlib
When selectingzstd
or setting zlib compression level(zlib:[1-9]
) user must ensure kernel version is >=4.14.x.
When selecting zstd compression level (zstd:[1-15]
) both the host and the target kernel version must be >=5.1.x since kernel started supporting zstd compression ratio only from 5.1 on.
Note: The script does not check the legality of input variable (compression ratio). Input likezlib:1234
is legal to the script but illegal to the kernel. Beware that setting this option does affect image creation only (shrinking disk size) and will not adjust/etc/fstab
so it is up to the user to later edit/etc/fstab
if compression in daily operation is also wanted (beware of serious performance penalties with random IO patterns and heavy compression algorithms!). - FORCE_BOOTSCRIPT_UPDATE ( yes | no ): - yes: force bootscript to get updated during bsp package upgrade
- NAMESERVER (
IPv4 address
): the DNS resolver used inside the build chroot. Does not affect the final image. Default:1.0.0.1
- DOWNLOAD_MIRROR (
china
|bfsu
): select download mirror fortoolchain
anddebian/ubuntu packages
-china
: usemirrors.tuna.tsinghua.edu.cn
, it will be very fast thanks to Tsinghua University -bfsu
: usemirrors.bfsu.edu.cn
, mirror of Beijing Foreign Studies University
- leave empty to use official source - ARMBIAN_MIRROR (auto): override automated mirror selection, example ‘ARMBIAN_MIRROR=”https://yourlocalmirror.com”’
- MAINLINE_MIRROR (
google
|tuna
|bfsu
): select mainline mirror oflinux-stable.git
-google
: use mirror provided by Google, the same asUSE_MAINLINE_GOOGLE_MIRROR=yes
-tuna
: use mirror provided by Tsinghua University -bfsu
: use mirror provided by Beijing Foreign Studies University which is similar totuna
- leave empty to use officalgit.kernel.org
, may be very slow for mainland China users - UBOOT_MIRROR (
github
|gitee
: select mainline mirror ofu-boot.git
-github
: use mirror provided by github, the same asUSE_GITHUB_UBOOT_MIRROR=yes
-gitee
: use mirror provided by Gitee, a Chinese git services - leave empty to use officalsource.denx.de
, may be very slow for mainland China users - GITHUB_MIRROR (
fastgit
|gitclone
|cnpmjs
): select download mirror for GitHub hosted repository -fastgit
: use mirror provided by fastgit.org -gitclone
: use mirror provided by gitclone.com -cnpmjs
: use mirror provided by cnpmjs.org - leave empty to connect directly to GitHub, may be very slow for mainland China users - REGIONAL_MIRROR (
china
): select mirrors based on regional setting, will not overwrite explicitly specified mirror option -china
: MAINLINE_MIRROR=tuna
, UBOOT_MIRROR=gitee
, GITHUB_MIRROR=fastgit
, DOWNLOAD_MIRROR=china
- leave empty to use default settings - USE_TORRENT ( yes | no ): use torrent to download toolchains and rootfs
- ROOT_FS_CREATE_ONLY ( yes | no ): set to yes to force local cache creation
- EXTRAWIFI ( yes | no ): include several drivers for WiFi adapters
- WIREGUARD ( yes | no ): include Wireguard for kernels before it got upstreamed to mainline. Will lose functionality soon.
- AUFS ( yes | no ): Include support for AUFS
- SKIP_BOOTSPLASH ( yes | no ): Use kernel bootsplash. Disable in case of troubles
- CONSOLE_AUTOLOGIN ( yes | no ): Automatically login as root for local consoles. Disable if your security threat model requires.
- EXT (
fake-vcgencmd
): execute extension during the build -fake-vcgencmd
: include fake vcgencmd to monitor and control boards from Android - INCLUDE_HOME_DIR ( yes | no ): Include directories created inside /home in final image.
