Armbian Build Framework Quick Start Guide
Requirements
  • x86_64 / aarch64 / riscv64 machine
  • at least 8GB (less for non-BTF builds) of memory and ~50GB of disk space for VM, container, or bare-metal installation
  • Armbian / Ubuntu Noble 24.04.x for native building or any Docker capable Linux for containerised
  • Windows 10/11 with WSL2 subsystem running Armbian / Ubuntu Noble 24.04.x
  • Superuser rights (configured sudo or root access).
  • Make sure your system is up-to-date! Outdated Docker binaries, for example, can cause trouble
Clone repository
Bash
git clone https://github.com/armbian/build
cd build
Note
  • Make sure that full path to the build script does not contain spaces
  • For stable branch use last point release --branch=v24.11
gitGraph
   commit
   commit
   checkout main
   commit id: "v24.08" tag: "v24.08"
   branch v24.08
   commit
   commit
   commit
   commit
   checkout main
   commit id: "v24.11" tag: "v24.11"
   branch v24.11
   commit
   commit
   commit
   commit
   checkout main
   commit
   commit
   commit
   commit
   commit
   commit
   commit id: "main" type: REVERSE tag: "Trunk"
Interactive
Run framework:
Bash
./compile.sh
Video
CLI
Bash
./compile.sh [command] [switch...] [config...]
Troubleshooting: ‘unknown terminal type’ error
When running the script, especially from modern terminal emulators (like Ghostty, Kitty, WezTerm), you might encounter an error like
‘xterm-ghostty’: unknown terminal type
Quick workaround: you can force a more common terminal type before running the script:
Bash
env TERM=xterm-256color ./compile.sh
Only one command can be specified.
Switches are parameter settings that are used by the build framework itself (e.g. DEBUG=yes) or the specific command.
Config files are bash shell scripts that are sourced in the order specified. They are primarily used to set switches but might also set hook functions. They must be located in the userpatches directory and must be named config-${arg}.conf or config-${arg}.conf.sh (where ${arg} is the argument from the command line): one or the other, but not both.
Switches set on the commandline override settings from the config files, regardless of the order they appear on the comandline.
Comprehensive list of build Commands and Switches
Example:
Bash
./compile.sh build \
BOARD=uefi-x86 \
BRANCH=current \
BUILD_DESKTOP=yes \
BUILD_MINIMAL=no \
DESKTOP_APPGROUPS_SELECTED='browsers chat desktop_tools' \
DESKTOP_ENVIRONMENT=gnome \
DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base \
KERNEL_CONFIGURE=no \
RELEASE=noble
Or, using config file userpatches/config-myboard.conf that sets all these switches:
Bash
myboard
Interpretation?
This command will generate Ubuntu 24.04 Noble based Gnome desktop environment image for Intel based hardware (uefi-x86). Besides bare desktop, it will contain packages from browsers and desktop_tool sections and it will use unchanged kernel from current kernel branch.
Logging
Logs are written to output/logs. Old logs (all but the current build) are compressed and moved to output/logs/archive.
Log formats are:
  • ANSI - text with ANSI escapes for color coding - *.log.ans
  • ASCII (if ansi2txt is available) - text without color coding escapes - *.log
  • Markdown summary - *.md
  • Raw (if RAW_LOG=yes) - tar file containg all the raw logs - *.raw.tar
For much more verbose logs set switch ‘DEBUG=yes’.
GitHub Actions
If you do not have the proper equipment to build images on your own, you can use our GitHub Action.
Minimal workflow example
Create .github/workflows/build.yml in your repository:
YAML
name: Build Armbian Image
on:
  workflow_dispatch:
jobs:
  build:
    runs-on: ubuntu-latest # ubuntu-24.04-arm, ubuntu-24.04-riscv
    steps:
      - uses: armbian/build@main
        with:
          armbian_token: ${{ secrets.GITHUB_TOKEN }}
          armbian_board: "uefi-x86" # orangepi5 bananapif3
          armbian_release: "noble" # trixie
          armbian_target: "build"
          armbian_ui: "minimal" # server xfce
          armbian_runner_clean: "yes" # recommended for Github runners
The action will build the image, create a GitHub Release in your repository and upload the artifacts.
Inputs reference
Input Required Default Description
armbian_token yes GitHub access token (GITHUB_TOKEN or a PAT)
armbian_board no uefi-x86 Hardware platform (e.g. orangepi5, rock-5b)
armbian_target no kernel Build target: kernel or build (full image)
armbian_branch no main Armbian framework branch
armbian_kernel_branch no current Kernel branch: current, edge, etc.
armbian_release no noble Userspace release (e.g. noble, bookworm, trixie)
armbian_ui no minimal minimal, server, or a desktop environment name (e.g. xfce, gnome)
armbian_version no auto Override version; patch level is auto-incremented from stable.json if not set
armbian_compress no sha,img,xz Output compression method
armbian_extensions no Comma-separated list of build extensions to enable
armbian_pgp_key no GPG private key for image signing (store as a secret)
armbian_pgp_password no GPG passphrase (store as a secret)
armbian_release_title no Armbian image GitHub Release title
armbian_release_body no (link to build tools) GitHub Release body text
armbian_release_tag no auto GitHub Release tag; defaults to the computed version
armbian_artifacts no build/output/images/ Path to artifacts for upload
armbian_runner_clean no Set to any non-empty value to free disk space on GitHub-hosted runners
Customisation
If your repository contains a userpatches/ directory, it will be merged into the build framework automatically. This allows you to add custom kernel configs, patches, or overlay files without forking the main build repository.
