Armbian Config¶
flowchart LR
A[armbian-config] -----> B["System"];
A[armbian-config] -----> C["Network"];
A[armbian-config] -----> D["Localisation"];
A[armbian-config] -----> E["Software"];
A[armbian-config] -----> F["Help"];
Utility for configuring your board, adjusting services, and installing applications. It comes with Armbian by default.
To start the Armbian configuration utility, use the following command:
| Text Only | |
Adding a new feature¶
Please check instructions.
Sources¶
Installation on 3rd party Linux OS¶
This tool is tailored to works best with Armbian Linux but it has also been automatically tested on:
- Debian Bookworm
- Ubuntu Jammy
- Ubuntu Noble
In theory it should work on any systemd APT based Linux distributions such as: Linux Mint, Elementary OS, Kali Linux, MX Linux, Parrot OS, Proxmox, Raspberry Pi OS, …
