Build commands¶
kernel¶
Builds kernel and device tree (where applicable) and places it to the output/debs
Usage:
| Bash | |
kernel-config¶
Automatically call kernel’s make menuconfig (add or remove modules or features)
Usage:
| Bash | |
dts-check¶
Validate dts files and improve board & patch development overall.
This option validates the dts/dtb file for the selected board against the device tree bindings and outputs the validation logs to the user. It can be used when adding a new board, developing or improving a dts file.
Usage:
| Bash | |
inventory-boards¶
Outputs a one-board-per-line CSV inventory of boards.
Sets TARGETS_FILE to something that doesn’t exist, so the default-targets.yaml is used (so same list for everyone, save for userpatched-boards)
Usage:
| Bash | |
kernel-dtb¶
Builds only DTB and outputs full preprocessed dts source
Outputs preprocessed DTS source for the board in question to output/
also outputs the same preprocessed DTS source, ran through dtc with input and output DTS formats for “normalized” comparisons
Usage:
| Bash | |
uboot-patch¶
Create patch files for u-boot.
The output patch files are written to output/patch/u-boot-${LINUXFAMILY}-${BRANCH}.patch. To use them in subsequent builds they must be copied to the appropriate directories in the patch/u-boot directory. See: user-provided patches
Any uncommited changes in the work tree and index are commited
to establish a clean work tree.
It would be best if there are no uncommitted changes when running
uboot-patch.
If there is an existing patch file at the output path specified above, it may be applied before continuning work.
When the prompt Press <ENTER\> after you are done editing in ${pwd} appears,
in a separate window, navigate to the specified directory
and make any required changes.
When changes are complete,
return to the window running the uboot-patch command
and press <ENTER>.
A patch to recreate the changes introduced to the u-boot tree is presented
and the prompt “Are you happy with this patch?”.
You can response
yes to accept the patch as-is and generate the output patch file,
stop to abort the command without producing the outpu patch file,
or anything else to loop back, to make futher changes.
Instead of creating them while running uboot-patch,
new device tree files should be created in the relevant dt directory under
patch/u-boot
and new _defconfig files should be created in the relevant configs directory
under patch/u-boot.
While the uboot-patch command will add these new files to the patch
if they are created while running uboot-patch,
this is not the preferred way of adding these files.
rewrite-uboot-patches¶
Prepares git, applies patches to git, and rewrites them back from git same as kernel, it does git archeology for mbox-less patches, etc.
Note: MAINTAINER and MAINTAINEREMAIL should be set.
- uboot-patches-to-git alias is also added, but my guess is that the rewrite is more useful.
- refactor a common config function for both kernel and uboot.
Usage:
| Bash | |
rewrite-kernel-patches¶
Usage:
| Bash | |
targets¶
Generates output/info/git_sources.json file containing URL, branch, and commit hash combo.
The easiest way to generate file for all devices is to run ./compile.sh targets. Then, at the time of release, we will copy the output/info/git_sources.json file to config/sources/git_sources.json. Once the file is copied, the hash information from the file will be used to fetch resources for git repositories where branches are specified instead of tags or commits.
Usage:
| Bash | |
