Extension Hooks
  • This file is autogenerated by the armbian/build repository.
Hooks
post_family_config
give the config a chance to override the family/arch defaults
This hook is called after the family configuration (sources/families/xxx.conf) is sourced. Since the family can override values from the user configuration and the board configuration, it is often used to in turn override those.
Also known as (for backwards compatibility only):
  • config_tweaks_post_family_config
user_config
Invoke function with user override
Allows for overriding configuration values set anywhere else. It is called after sourcing the lib.config file if it exists, but before assembling any package lists.
extension_prepare_config
allow extensions to prepare their own config, after user config is done
Implementors should preserve variable values pre-set, but can default values an/or validate them. This runs after user_config. Don’t change anything not coming from other variables or meant to be configured by the user.
post_aggregate_packages
For final user override, using a function, after all aggregations are done
Called after aggregating all package lists, before the end of compilation.sh. Packages will still be installed after this is called, so it is the last chance to confirm or change any packages.
  • user_config_post_aggregate_packages
post_determine_cthreads
give config a chance modify CTHREADS programatically. A build server may work better with hyperthreads-1 for example.
Called early, before any compilation work starts.
  • config_post_determine_cthreads
add_host_dependencies
run before installing host dependencies
you can add packages to install, space separated, to ${EXTRA_BUILD_DEPS} here.
fetch_sources_tools
fetch host-side sources needed for tools and build
Run early to fetch_from_repo or otherwise obtain sources for needed tools.
build_host_tools
build needed tools for the build, host-side
After sources are fetched, build host-side tools needed for the build.
pre_install_distribution_specific
give config a chance to act before install_distribution_specific
Called after create_rootfs_cache (prepare basic rootfs: unpack cache or create from scratch) but before install_distribution_specific (install distribution and board specific applications).
  • config_pre_install_distribution_specific
pre_install_kernel_debs
called before installing the Armbian-built kernel deb packages
It is not too late to unset KERNELSOURCE here and avoid kernel install.
post_install_kernel_debs
allow config to do more with the installed kernel/headers
Called after packages, u-boot, kernel and headers installed in the chroot, but before the BSP is installed. If KERNELSOURCE is (still?) unset after this, Armbian-built firmware will not be installed.
post_family_tweaks
customize the tweaks made by $LINUXFAMILY-specific family_tweaks
It is run after packages are installed in the rootfs, but before enabling additional services. It allows implementors access to the rootfs (${SDCARD}) in its pristine state after packages are installed.
pre_customize_image
run before customize-image.sh
This hook is called before customize-image.sh is executed and before the overlay is mounted. It thus can be used for the same purposes as customize-image.sh without the overlay.
  • image_tweaks_pre_customize
post_customize_image
post customize-image.sh hook
Run after the customize-image.sh script is run, and the overlay is unmounted.
  • image_tweaks_post_customize
post_post_debootstrap_tweaks
run after removing diversions and qemu with chroot unmounted
Last chance to touch the ${SDCARD} filesystem before it is copied to the final media. It is too late to run any chrooted commands, since the supporting filesystems are already unmounted.
  • config_post_debootstrap_tweaks
pre_prepare_partitions
allow custom options for mkfs
Good time to change stuff like mkfs opts, types etc.
  • prepare_partitions_custom
prepare_image_size
allow dynamically determining the size based on the $rootfs_size
Called after ${rootfs_size} is known, but before ${FIXED_IMAGE_SIZE} is taken into account. A good spot to determine FIXED_IMAGE_SIZE based on rootfs_size. UEFISIZE can be set to 0 for no UEFI partition, or to a size in MiB to include one. Last chance to set USE_HOOK_FOR_PARTITION=yes and then implement create_partition_table hook_point.
  • config_prepare_image_size
post_create_partitions
called after all partitions are created, but not yet formatted
format_partitions
if you created your own partitions, this would be a good time to format them
The loop device is mounted, so ${LOOP}p1 is it’s first partition etc.
pre_update_initramfs
allow config to hack into the initramfs create process
Called after rsync has synced both /root and /root on the target, but before calling update_initramfs.
  • config_pre_update_initramfs
pre_umount_final_image
allow config to hack into the image before the unmount
Called before unmounting both /root and /boot.
  • config_pre_umount_final_image
post_umount_final_image
allow config to hack into the image after the unmount
Called after unmounting both /root and /boot.
  • config_post_umount_final_image
post_build_image
custom post build hook
Called after the final .img file is built, before it is (possibly) written to an SD writer.
  • NOTE: this hook used to take an argument ($1) for the final image produced. - Now it is passed as an environment variable ${FINAL_IMAGE_FILE} It is the last possible chance to modify $CARD_DEVICE.
run_after_build
hook for function to run after build, i.e. to change owner of $SRC
Really one of the last hooks ever called. The build has ended. Congratulations.
  • NOTE: this will run only if there were no errors during build process.
extension_metadata_ready
meta-Meta time!
Implement this hook to work with/on the meta-data made available by the extension manager. Interesting stuff to process:
  • "${EXTENSION_MANAGER_TMP_DIR}/hook_point_calls.txt" contains a list of all hook points called, in order.
  • For each hook_point in the list, more files will have metadata about that hook point. - ${EXTENSION_MANAGER_TMP_DIR}/hook_point.orig.md contains the hook documentation at the call site (inline docs), hopefully in Markdown format. - ${EXTENSION_MANAGER_TMP_DIR}/hook_point.compat contains the compatibility names for the hooks. - ${EXTENSION_MANAGER_TMP_DIR}/hook_point.exports contains exported environment variables. - ${EXTENSION_MANAGER_TMP_DIR}/hook_point.vars contains all environment variables.
  • ${defined_hook_point_functions} is a map of all the defined hook point functions and their extension information.
  • ${hook_point_function_trace_sources} is a map of all the hook point functions that were really called during the build and their BASH_SOURCE information.
  • ${hook_point_function_trace_lines} is the same, but BASH_LINENO info. After this hook is done, the ${EXTENSION_MANAGER_TMP_DIR} will be removed.
