Welcome to the Armbian build framework documentation!¶
Overview:
(ANSI) Logging¶
Log output is stored in output/logs and provided in a few different formats. ANSI coloring is applied to both the screen and the log files themselves.
Please add SHARE_LOG=yes to automatically upload logs to our paste service and provide us with the given url when reporting issues.
That will allows us to check the logs on a web browser and keep to correct formatting.
Command line syntax has changed¶
General CLI syntax: ./compile.sh PARAM=value OTHER_PARAM=other_value [<configfile> <configfile> ...] [<command>]
- where
commanddefaults tobuildif not specified; could also bekernel-configoru-bootetc… - config file names must not have the same name as a possible
<command>(system will check & bomb if so) - also: there is no more
defaultconfig – you have to be explicit - also: there is no more
dockerconfig – Docker is fully auto-managed now. The system will complain if you have one. - parameters like
PARAM=value,<configfile>or<command>can be applied in any order.
No more config-default.conf, config file name needs to be specified in the command line¶
- No “default” config is auto-loaded anymore. Default config lead to unreproducible failing builds and was a source of confusion.
- The configs still go to the same place,
userpatches/config-xyz.conf– but the name has to be provided to the build system to, like./compile.sh BOARD=xxx xyz; otherwise works the same.
Artifacts, cache, what the …?¶
The armbian/build system is currently undergoing refactoring to improve its structure. Previously, the build system
was a single, very complex bash script that mixed the building of .deb packages with the creation of images.
This was reworked into a 1-to-N image-to-artifact dependency tree; a certain image build will depend on N possible
“artifacts”. Artifacts are either .deb packages, a .tar of multiple .deb packages, or a rootfs.tar.zstd. Each
artifact can be individually built, and has a specific name and a version.
Each artifact is also now cached by default using OCI storage at ghcr.io (GitHub Container Registry). To achieve consistent caching, each artifact produces a version that includes hashes of its composing files, variables, patches, hooks, external git SHA1 references, etc. That way we can consistently check the remote OCI cache for previously-built artifacts, and possibly save image builders from having to build heavy packages just to produce an image.
TL;DR about artifacts and caching:¶
KERNEL_ONLY=yesandKERNEL_ONLY=noare deprecated. Use thekernelCLI command instead.ARTIFACT_IGNORE_CACHE=yescan help with false positives. Please also report the problem, with a complete logfile.
Automatic Docker/sudo launcher¶
compile.shwill prefer to use Docker if it detects Docker is installed and working. - This handles Docker Desktop and Rancher Desktop (in Docker emulation mode) under macOS/Darwin, including Apple M1/M2. - You don’t need and actually can’t have the old docker config file.- If Docker is not installed, it will try to use
sudoto run the build as root. - If you run directly as root, it will give a warning and asks to run without
sudo.
Kernel Git Trees: shallow vs full¶
During the build, depending on which local or remote caches are hit, it might be necessary to build the Linux Kernel from scratch.
The kernel’s git repo is huge. Most build systems resort to fetching “shallow” trees directly from upstream git servers,
to save bandwidth. Unfortunately that creates immense extra CPU load on the git servers. To avoid this problem,
Armbian produces daily automated git tree exports cached in ghcr.io OCI repositories, and only uses git fetch to
update the relatively small new changes from the upstream git server.
There are two types of cached Kernel git trees:
fullis a complete git tree, including all of Torvald’smasterand all of the currently-supportedstablebranches. -fullis very large download and requires a lot of disk space. -fullis more useful over time and when building multiple different kernels on the same machine, like for CI servers or developer workstations.shallowis a shallow tree for a specificstablebranch -shallowis a much smaller download and requires less disk space -shallowis appropriate for restricted devices like SBCs which will build a single kernel
**TL;DR: ** KERNEL_GIT=full or KERNEL_GIT=shallow or let the system decide for you.
Consider forking before cloning the repo¶
Before cloning the repo, consider forking it first. This will allow you to make changes and submit pull requests. You will need a GitHub account to do this; see GitHub’s documentation for more information. If you fork, make sure to keep your fork up-to-date with the main repo, by rebasing your fork.
Some really confusing stuff still remains¶
This is (by far) not a complete list:
- wifi/other kernel drivers are still using pre-armbian-next code, and are very hard to work with. it is not only the contents are a mess, the way the whole thing works leads to more and more compounding work. To make it worse, family patches sometimes need to patch driver code, leading to a cycle of sadness for developers. We are still coming up with a plan to completely replace this lest most of us go insane.
- although “aggregation” has been rewritten in Python, it still mostly works using the legacy principle, by scanning directories and files in a very complex and error-prone way. This is a source of many bugs and confusion. We plan to replace this with pure extensions eventually.
- we have mostly working kernel headers (linux-headers pkg) for 5.10+ including some vendor kernels
Multiple u-boot’s for same board¶
We can build u-boot twice, using UBOOT_TARGET_MAP. Some example I did in https://github.com/armbian/build/blob/main/config/boards/odroidhc4.conf#L15-L20 may help.
