Device Tree overlays¶
Most in-circuit and GPIO based interfaces (SPI, I2C, I2S, UART, …) don’t have a mechanism for detecting and identifying devices connected to the bus, so Linux kernel has to be told explicitly about the device and its configuration details.
While Device Tree is a way of describing hardware configuration to the kernel, Device Tree overlays are a way for modifying the DT in order to provide the kernel and kernel drivers with details about external devices or to activate interfaces disabled by default.
Note: from the Linux kernel maintainer perspective all unused in-circuit type interfaces that use GPIO pins should be disabled by default and all pins on pin headers or soldering pads will be configured as standard GPIOs.
Note: from the Linux kernel maintainer perspective all dedicated interfaces like USB, Ethernet or analog audio that are wired to soldering pads or a pin headers instead of specialized sockets (like USB socket, Ethernet socket or 3.5mm jack) will be left disabled by default.
Armbian specific notes¶
- DT overlays are a Work-in-Progress (WIP) feature, present only in certain images.
- Please note that different SoCs will have different sets of available overlays.
Quick start¶
- Check the
README.<soc-id>-overlays
in/boot/dtb/overlay/
(32-bit SoCs) or/boot/dtb/allwinner/overlay/
(64-bit SoCs) for a list of provided overlays, their required and optional parameters - Add names of overlays you want to activate to
overlays=
line in/boot/armbianEnv.txt
, separated with spaces - Add required parameters with their values to
, one per line - Add optional parameters with their values to
if you want to change the default value, one per line - If you didn’t find the required overlay or want to change one of provided overlays, refer to “Using custom overlays” section
- Reboot
Using custom overlays¶
- Check here for some example overlays
- Copy or create your overlay file (with
.dts
extension) on the device - Change I2C or SPI bus number, GPIO and pinctrl pins,
compatible
string to match your SoC if necessary - Compile and activate the overlay by running
armbian-add-overlay <overlay_file.dts>
as root, i.e.sudo armbian-add-overlay sht15.dts
- Reboot
armbianEnv.txt entries reference¶
overlay_prefix
- prefix for the DT and overlay file names, set at OS image creation timeoverlays
- list of overlays to activate from kernel directoryuser_overlays
- list of overlays to activate from/boot/overlay-user/
directoryparam_*
- overlay parameters
Kernel provided vs user provided overlays¶
Overlays can be loaded from 2 locations:
/boot/dtb/overlay/
(/boot/dtb/allwinner/overlay/
for 64-bit SoCs) - kernel provided overlays/boot/overlay-user/
- user provided overlays
Main differences between these locations:
- Kernel provided overlays are updated with the kernel packages, any changes to this directory (including new files) will be lost on kernel upgrade
- Kernel provided directory may contain overlays for different SoCs, so overlay file name pattern will be
<prefix>-<name>
, for examplesun8i-h3-i2c0.dtbo
, wheresun8i-h3
is the prefix andi2c0
is the name - Kernel provided overlays are activated by the overlay name (i.e.
i2c0
), and the prefix is set at OS image creation time - User provided overlays directory is empty by default and is meant for storing and using user created overlays that are not present in the kernel packages or modified stock overlays
- User provided overlays are activated by the file name (excluding the extension), i.e. for file
adafruit13m.dtbo
overlay name would beadafruit13m
Activation¶
DT overlays are activated by editing u-boot environment file /boot/armbianEnv.txt
- Kernel provided overlays are activated by adding a name to the
overlays
variable - User provided overlays are activated by adding a name to the
user_overlays
variable - No more than one
overlays
line and oneuser_overlays
line can be present in the environment file - Multiple names should be separated by space
- If activated overlays have parameters marked as “Required”, those parameters have to be set to proper values
- Reboot is required for any changes to take effect
Overlay parameters¶
Some overlays have additional parameters that can be set.
Parameters marked as “Required” have to be set if overlay with these parameters is activated, other parameters are not mandatory if default value is suitable.
Parameters are set by adding their name and value to /boot/armbianEnv.txt
, each parameter should be added on a new line.
Please refer to README.<SoC_prefix>-overlays
files in /boot/dtb/overlay/
for 64-bit SoCs) directory for supported parameters, i.e. README.sun8i-h3-overlays
for H3 based boards.
Parameters of type pin
require special format:
- Value consists of a letter
P
, a letter that signifies the pin bank and a number of the pin in the bank - Letters should be upper case
- Numbers should not contain leading zeros
- Examples: good -
PA9
,PG12
; bad -pa2
,PG08
Overlay bus selection¶
SoCs may contain multiple bus controllers of the same type, i.e. Allwinner H3 contains 2 SPI controllers and Allwinner A20 contains 4 SPI controllers.
Please refer to your board documentation and schematic to determine what pins are wired to the pin headers and thus what bus number should be used in each case.
Overlay pinmux conflicts¶
Some controllers may share the SoC pins in some configurations. For example on Allwinner H3 UART 3 and SPI 1 use the same pins - PA13
, PA14
, PA15
, PA16
In this case activating both UART 3 and SPI 1 would result in a conflict, and on practice only one interface (either SPI or UART) will be accessible on these pins.
Please check the SoC specific README, board schematic, SoC datasheet or other documentation if you are unsure about possible conflicts if activating multiple overlays for the controllers that use shared (muxed) pins.
Overlay device endpoint conflicts¶
Overlays for devices that use addresses or similar mechanisms (i.e. SPI chip selects) can’t be activated simultaneously if addresses (chip selects) are identical.
For example A20 SPI controller 1 has only one hardware chip select, so spi-spidev
and spi-jedec-nor
overlays cannot be activated both if they would use the same bus number and chip select.
Overlay compatibility¶
Device Tree overlays for different platforms and SoCs are not directly compatible. This, for example, means that overlays for H3 may need some changes to work on A20, and that Raspberry Pi overlays will need adjustments in order to be used on Allwinner based boards.
Rework may include changing labels, references (phandles) and pinconf bindings.
Notes regarding SPI and I2S overlays¶
Activating a device on SPI or I2S bus may require more than one overlay.
In case a bus overlay like spi0
or i2s0
exist for the target SoC they need to be activated in addition to a slave device overlay (provided or custom/user-made).
Please note that these overlays (spi0
, i2s0
) do not enable any slave devices (like spidev or I2S codec).
In some cases it might be necessary to change param_spidev_spi_bus
to 1
Debugging¶
As overlays and overlay parameters are applied by the u-boot, it is impossible to get any debugging information (such as error messages) from the OS.
Serial console on UART 0 is required to debug DT overlay related problems.
Example /boot/armbianEnv.txt
contents:¶
Text Only | |
1 2 3 4 5 6 7 8 9 10 |
Example of serial console log when using several overlays:¶
Text Only | |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 |
