Extension: ccache-remote
ccache significantly speeds up repeated kernel and U-Boot builds by caching compiled objects. By default, each build host has its own local cache. This extension adds a shared remote cache so that multiple build machines (or a CI server and a developer workstation) can all benefit from objects already compiled by someone else.
Typical scenarios:
  • A home lab with several SBCs used as build hosts — first build populates the cache, subsequent builds on other machines hit it.
  • A CI server and developer laptops sharing one cache server so that a developer rarely needs to compile from scratch after CI has run.
  • A single machine where the local cache was lost (disk wiped) but the remote cache is still warm.
The extension supports two backends:
  • Redis — lower latency, recommended for fast local networks. Cache lives entirely in RAM on the server, so capacity is limited by available memory.
  • HTTP/WebDAV (nginx) — somewhat slower, but stores cache on disk. Can be orders of magnitude larger than a RAM-backed Redis instance, making it a better choice when cache size matters more than speed.
Auto-discovery vs. explicit configuration
The simplest deployment uses Avahi (DNS-SD). Once the cache server is set up and publishing its service, and Avahi is installed on all build hosts, enabling the extension is all that is needed — no URL configuration required.
If Avahi is not available or not desirable, the server URL must be provided explicitly via CCACHE_REMOTE_STORAGE, or for remote servers via CCACHE_REMOTE_DOMAIN (DNS SRV). See Parameters below.
The extension automatically enables USE_CCACHE=yes and handles all ccache configuration including Docker pass-through.
Quick start
If a cache server is already running on the local network and advertising itself via DNS-SD (Avahi), no configuration is needed:
Bash
./compile.sh BOARD=<board> BRANCH=<branch> ENABLE_EXTENSIONS="ccache-remote"
With an explicit Redis server:
Bash
1
2
3
./compile.sh BOARD=<board> BRANCH=<branch> \
  ENABLE_EXTENSIONS="ccache-remote" \
  CCACHE_REMOTE_STORAGE="redis://192.168.1.65:6379"
With an explicit HTTP/WebDAV server:
Bash
1
2
3
  CCACHE_REMOTE_STORAGE="http://192.168.1.65:8088/ccache/"
To enable permanently from a userconfig file:
Bash
1
2
3
enable_extension "ccache-remote"
# optionally:
# CCACHE_REMOTE_STORAGE="redis://192.168.1.65:6379"
Requirements
  • ccache: version 4.4 or newer (for remote storage support).
  • Redis backend: Redis server accessible from the build host.
  • HTTP backend: nginx with WebDAV module (nginx-extras).
  • Auto-discovery: avahi-browse (package avahi-utils) on the build host.
Parameters
Variable Default Description
CCACHE_REMOTE_STORAGE (empty) Remote storage URL. If not set, auto-discovery is attempted.
CCACHE_REMOTE_DOMAIN (empty) Domain for DNS SRV discovery (e.g. example.com).
CCACHE_REMOTE_ONLY no Set to yes to disable local cache and use only remote storage (saves local disk space).
CCACHE_REDIS_CONNECT_TIMEOUT 500 Redis connection timeout in milliseconds.
CCACHE_READONLY (empty) Set to any value to use cache read-only (don’t write new entries).
CCACHE_RECACHE (empty) Recompile everything and update cache (bypass existing entries).
CCACHE_RESHARE (empty) Push existing local cache entries to remote storage.
CCACHE_MAXSIZE (empty) Maximum local cache size (e.g. 10G).
CCACHE_NAMESPACE (empty) Namespace for cache isolation between projects or branches.
CCACHE_DISABLE (empty) Set to any value to disable ccache completely.
For the full list of supported variables see the CCACHE_PASSTHROUGH_VARS array in the extension source or the ccache configuration reference.
CCACHE_REMOTE_STORAGE URL format
Text Only
Redis:  redis://[[USER:]PASSWORD@]HOST[:PORT][|attribute=value...]
HTTP:   http://HOST[:PORT]/PATH/[|attribute=value...]
Common attributes:
Attribute Default Description
connect-timeout 100 ms Connection timeout. Increase on slow networks.
operation-timeout 10000 ms Per-operation timeout.
Examples:
Text Only
1
2
3
redis://192.168.1.65:6379|connect-timeout=500
redis://default:secretpass@192.168.1.65:6379|connect-timeout=500
Warning
Redis passwords must not contain /, +, =, or spaces — these break URL parsing. Generate a safe password with:
Bash
openssl rand -hex 24
Server discovery
When CCACHE_REMOTE_STORAGE is not set, the extension tries to discover a cache server automatically in this order:
  1. DNS-SD (mDNS / Avahi): browse for _ccache._tcp on the local network. Requires avahi-browse on the build host and the cache server publishing a DNS-SD service. Redis is preferred over HTTP when both are found.
  2. DNS SRV: query _ccache._tcp.DOMAIN when CCACHE_REMOTE_DOMAIN is set. Useful for remote or cloud-hosted build servers.
  3. Legacy mDNS: resolve the hostname ccache.local (falls back to Redis on port 6379). Kept for backward compatibility.
If none of these succeeds, the extension silently falls back to local cache only.
Cache sharing requirements
For the cache to be shared across multiple build hosts, the Armbian source tree must be at the same path on all machines (e.g. /home/build/armbian). ccache includes the working directory in the cache key, so different paths produce different keys and the cache will not be shared.
Docker builds are not affected — they always use a consistent internal path.
Server setup
  1. Install:
    Bash
    apt install redis-server avahi-daemon avahi-utils
  2. Configure Redis — copy misc/redis/redis-ccache.conf from the extension directory and include it in /etc/redis/redis.conf:
    Bash
    echo "include /etc/redis/redis-ccache.conf" >> /etc/redis/redis.conf
    systemctl restart redis-server
  3. Set a password (recommended for any non-isolated network):
    Bash
    openssl rand -hex 24   # use output as password
    # set requirepass <password> in redis-ccache.conf
  4. Publish the DNS-SD service so clients discover it automatically:
    Bash
    1
    2
    3
    4
    5
    6
    # Static (always advertise):
    cp misc/avahi/ccache-redis.service /etc/avahi/services/
    # Or tied to redis-server lifecycle:
    cp misc/systemd/ccache-avahi-redis.service /etc/systemd/system/
    systemctl enable --now ccache-avahi-redis
HTTP/WebDAV (nginx)
  1. Install:
    Bash
    apt install nginx-extras avahi-daemon avahi-utils
  2. Enable the WebDAV site:
    Bash
    1
    2
    3
    4
    5
    cp misc/nginx/ccache-webdav.conf /etc/nginx/sites-available/ccache-webdav
    ln -s /etc/nginx/sites-available/ccache-webdav /etc/nginx/sites-enabled/
    mkdir -p /var/cache/ccache-webdav/ccache
    chown -R www-data:www-data /var/cache/ccache-webdav
    systemctl reload nginx
  3. Verify:
    Bash
    curl -X PUT -d "test" http://localhost:8088/ccache/test.txt
    curl http://localhost:8088/ccache/test.txt
    !!! warning The provided nginx configuration has no authentication. Use only on a trusted private network.
  4. Publish the DNS-SD service:
    Bash
    cp misc/avahi/ccache-webdav.service /etc/avahi/services/
DNS SRV records (remote servers)
For build hosts that cannot reach the cache server via mDNS, set CCACHE_REMOTE_DOMAIN and create DNS records:
Redis backend:
Text Only
_ccache._tcp.example.com.  SRV  0 0 6379 ccache.example.com.
_ccache._tcp.example.com.  TXT  "type=redis"
HTTP/WebDAV backend:
Text Only
_ccache._tcp.example.com.  SRV  0 0 8088 ccache.example.com.
_ccache._tcp.example.com.  TXT  "type=http" "path=/ccache/"
mDNS client requirements
For .local hostname resolution to work on the build host:
Bash
1
2
3
4
5
# Option A: systemd-resolved
apt install libnss-resolve
# Option B: standalone
apt install libnss-mdns
References
