Allwinner H6¶
See also generic Allwinner page,
CPU frequency¶
The H6 CPU frequency has ben soft-capped at 1,48 GHz to avoid thermal throttling too fast. This limit can be lifted by editing
/etc/default/cpufrequtils
and set MAX_SPEED
to 1810000
With the release of Armbian 20.05 “Kagu” new thermal zones have been added making this limitation obsolete and therefore has been removed. All H6 boards now clocking at the highest possible value OOB.
Warning Adding proper cooling is highly recommended.
PCIe (un-)supported¶
Some H6 SoC based boards (like Pine H64 Model a, discontinued) are shipped with a PCIe slot. This slot cannot work out of the box as it has to be considered as broken by design. Linux-Sunxi writes about this:
Allwinner H6 has a quirky PCIe controller that doesn’t map the PCIe address space properly (only 64k accessible at one time) to CPU, and accessing the PCIe config space, I/O space or memory space will need to be wrapped. As Linux doesn’t wrap PCIe memory space access, it’s not possible to do a proper PCIe controller driver for H6. The BSP kernel modifies the driver to wrap the access, so it’s also not generic, and only devices with modified driver will work.
Icenowy is working on a wrapper to make PCIe work. Check forums.
Networking¶
Trouble getting ethernet connection? Check here
