Marvel Armada Clearfog¶
Overview¶
None of kernels are fully functional so you need to try out which is best for your case.
LTS¶
System images with patched mainline 4.4.x kernel
- Kernel 4.4.x
- Docker ready
- Both mPCIe are operational and convertible to mSATA, M2 operational
- Added patch to unlock Atheros regulatory restrictions which unlock 5Ghz AP mode in cheap Atheros cards (ath9 driver)
- Bluetooth ready (working with supported external keys)
- I2C ready. Basic i2c tools included.
- SPI ready but untested.
- SFP ready and tested with a fibre 1G/1.25G module, requires configuring eth2 - static, DHCP or bridged (not configured by default)
- SFP DDMI is operational (
sudo ethtool -m eth2
Bugs or limitation¶
- DFS (Cpufreq) is not supported
Mainline¶
System images with mainline kernel
- Mainline kernel with large hardware support, headers and some firmware included
- Docker ready
Bugs or limitation¶
- SFP is not supported yet
Notes¶
- In case you ever run into troubles and ask for help in the forums please ensure to provide a serial console log (UART adapter on board accessible through Micro USB with 115200/8/N/1 settings)
- The boards can boot from various sources that are adjustable with a DIP switch. Comprehensive information about the necessary preparations available here.
